Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Jan 10, 2003 6:20 pm
243k, original injectors and harness and CAS;guides done @102k.Valve cover resealed at 180k, new plenum hoses at 78k and 220k.
Good time to check real idle oil pressure HOT to see if it exceeds oem 14 psi minimum in drive at 650 rpm to evaluate your future oil specifications.......10w X....30,40,50 or inbetween!
