StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Thu Feb 22, 2007 5:01 am
I promised to report on fitment and performance once I had my new wheels and tires installed on my 2005 Q45.
They fit perfectly, no interference at all. I'd like them to be a little further out to the fender line, but that's a personal thing. As it is, it's fine.
Okay, intial ride/handling report:
Ride is only slightly improved, probably due to the 100W load rating on the new 245/45 ZR18 Bridgestone Potenza RE050A "Pole Position" tires and the 36 psi inflation pressure I used initially. Original aftermarket tires on the car when I bought it were new Sumitomo245/35ZR20 -91 HTRZ II.
Hard turn-in, as in turning corners at lower speeds is not quite as quick as the 20" Sumitomos, but higher speed turn-in, as on curves seems to be slightly quicker and more responsive. Stability in turns is slightly better. Tracking is considerably better, and there's a lot less tramlining. Noise is reduced, and noise over potholes and expansion joints is better. My wife likes the ride better, and seems to notice the improvement more than I do. Of course, I'm busy trying to evaluate everything, and am not yet just relaxing and enjoying the ride. Understeer seems to be reduced considerably, thank God.
The tires are not broken in yet, and I'm still playing with inflation pressures. I usually run a few pouunds more pressure than manufacturer's specs, and in the case of these new tires, wanted to try them out @ 36 psi (spec is 33 psi) , then bleed them down early in the next AM. This morning early, I took them down to 34 psi.
So far, I like the tires. Discount Tire tells me that Bridgestone is conservative on their wear ratings, and that despite the 140 wear rating, these tires should give me over 20k miles. Not sure about that, but time will tell. I will of course, report further on these tires, both in overall performance and wear.
BTW, the TSW chrome "Kyalami" wheels look GREAT on this car! Despite being heavier than the better/lighter wheels on the market, for the $350 each price, I think they were a good deal, for me at least. Maybe later after I save some pennies, I'll go to BBS or OZ forged lightweight wheels and PS2 tires, but for now, these will have to do, and I like them.
