245/45/17wheels on S14...?
thanats
Car: 1996 240sx
Would I have problems with 245/45/17 wheels in the S14?
thx!
Beems240sx
Car: built S14, E30, R6 raven
thats a tire size bud, not a wheel size.
nicknasser300z32
Car: 1991 300zx na
wheels sporting 245's should fit in there. the 45 height should fit in there also my friend fit hit 225-50 18's in there with the car being only 3 inches from the ground on his s13....you might need wheel spacers depending on the rim it might be too close to the inside of the fender wall
thanats
Car: 1996 240sx
My bad.
Ok. So basically no problem fitting them in there
Thx!
sommmatt
Car: 1989 Nissan 240SX
nicknasser300z32 wrote:wheels sporting 245's should fit in there. the 45 height should fit in there also my friend fit hit 225-50 18's in there with the car being only 3 inches from the ground on his s13....you might need wheel spacers depending on the rim it might be too close to the inside of the fender wall
You know how tire size works right? First number is the width of the tire. Second number is the height of the sidewall, but a 245/50 tire won't have the same sidewall height has a 205/50 tire! the second number is the ratio of height to width!
HOWEVER that tire shouldn't have a problem fitting, it's not that wide.
