245/45/17
Blast down the 1320? Love the 1/8 mile action? Here's your forum.
Bullfrogg0
Car: 1989 Nissan 240sx
i recently ran across a good deal on a whole bunch of 245/45/17 tires....can't remember the brand....anyways...
what wheel would that go on, and will that fit under a lowered 240 coupe
gingerbredman
Car: 93 SE hatch, ~260k miles on the clock, 15" Enkei 92s, still stock. 2009 Sonata bouncing on Eibachs.
As a matter of fact I'm running that exact size on my rear right now. That's about 9 1/2" wide. I've got them on my ole Drifz wheels, 17x7, nothing special, the usual aftermarket offset. I know that probably sounds ridiculous but after researching I found out how wide a tire I could throw on that size wheel and the max was like 265 I think, before you started to have problems. I didn't want to push it though lol
If I can recall correctly, 245/45/17 tires won't fit on the front due to the strut being in the way. I'm currently running 215/45/17's on the front, the frt. wheels are also 17x7. 225/45/17 would probably fit in the front w/o a prob.
As far as fitting on a coupe I honestly don't know. I can tell you that on my old hatch I was running Eibach Sportline's (2.5"ish) drop and everything was good. On my current hatch I've got Dropzone springs with the wheels/tires, looks good, no rubs.
If the coupe and hatch aren't any different then yeah should fit. I'll post some pics up tomorrow if ya want to see.
AZ89two4Tsx
Around 9" depending on the look you want.
gingerbredman
myeah coupes are a little different in the rear, it's been raining but once it clears up a little I'll try and get some pics.
Scottsdale's not that far from Ft. Huachuca iirc
Return to “Nissan Drag Racing Forum”
