245/45/16 on lowered s14????
GrubyFngaz
Car: 2001 Infiniti QX4
I have intrax springs, and tokico blues with stock 16 in. wheels. I want to get some 245/45/16 on the rear, will I be ok? My fender hangs down past the tire right now with stock size tires on, will this make it impossible for the bigger tires? Thanks in advance.Josh
Exar-Kun
Car: 2005 350Z
Not with the stock wheels, thats far too wide of a tire to put on there safely.
Remember contact patch size is not a fuction of tire width. Only the shape is. The 205-55-16 tire that came on the stock SE wheels is the correct/best fitment for those wheels.
you can run a 225-50-16 if you feel the need to have a wider tire, but that's pushing the limits of "propper" fitment on the stock wheels.
-Chet
GrubyFngaz
Thanks Chet, I appreciate it.Josh
