I disagree with both AZhitman (7.5" rim width is too narrow for that width of tire with that aspect ratio) and Kevin.DuDro wrote:The OE Michelins are 245/45/18s...
I just wanted to make sure that the 0.48" decrease in sidewall height would not be too drastic for the rim and the overall size of the car.
Thanks for the input....
Tire sidewalls should be vertical or only slightly less for best performance, not[ stretched at all. Check the yokohama and TR websites for fitment information. I would stick to 245/45-18 on 8", but especially 7.5" width rims.Falkdesigns wrote:This is where it just comes down to taste, and I like the wheels to be wider than the tires. I'm not a fan of extremely stretched tires, but I like the side walls tilting in a bit, slightly stretched.
Very nice!Falkdesigns wrote:I want mine to be on the widest end of recomended wheel width for a particular tire width. I have 245 on a 9" wheel which is well within the recomended width and sidewalls are tilted in. The weels I'm getting are 9 f and 10 r, but I plan on running the same size tires I have now, 235 & 245.
True for your older Q, but DuDro has a 2003 Q45, whose stock tire size was 245/45-18, so his speedo would not be off!Jeff Williams wrote:Now I have 245/45/18's and the ride is phenominal. The speedo is off about 2 MPH at 80 (according to my GPS tracking system).
My tires are Nankang NSII, (see tire thread sticky) 235/40-18f, 245/40-18r, 95f and 97r load indexes, 45psiF, 42psiR. Over one year on them now, perfectly even wear (even with 2" drop), quiet, comfy, excellent traction wet and dry.maxnix wrote:Hope you are running XL load rated versions, as normal Michelin PS2 in those sizes are load rated at 91 and 93, whereas minimum OEM is 94.
I need to clarify that the set of tires on eBay have ~ 3K miles are selling for more than half the price of the new set, which are $1,100 from Tire Rack...DuDro wrote:
All the reviews for the Michelin Pilot Sport A/S are outstanding and I am eager to get these on my car. The only downside is the price, which will be close to $1,100 with shipping.
Agreed!DuDro wrote:I am considering new tires because the OE Michelin Pilot MXM4 tires are....how should I say this tastefully...CRAAAAP!!!
Hmmm ... some eBay deals may not be worth the money. Are they new? Is is a reputable dealer, etc.?DuDro wrote:I want to be better prepared for the DC-area winter weather, so I found a set of Michelin Pilot Sport A/S tires on eBay for an incredible price! The size of the tires are 245/40/18s.
Yes! They are expensive tires for sure. . I suggest that you consider one of the other A/S tires if price is a concern - like the Avon Tech M550 in a 245/45-18 size.DuDro wrote:All the reviews for the Michelin Pilot Sport A/S are outstanding and I am eager to get these on my car. The only downside is the price, which will be close to $1,100 with shipping.
I guess I will need to decide whether it's worth sacrificing the difference in ride going from a 245/45 to a 245/40.....
The Pilot AS, like any all season, is a serious compromise.DuDro wrote: I want to be better prepared for the DC-area winter weather, so I found a set of Michelin Pilot Sport A/S tires on eBay for an incredible price! The size of the tires are 245/40/18s.
Are you SURE those aren't 7.5" wide? You know, you are supposed to measure from bead surface to bead surface, not outer rim dimensions.AZhitman wrote:Don't fret too much over my fitments - Remember I have the 8" wide Premiums (which we've beaten into Horse Heaven).
So true.Jeff Williams wrote:Are you SURE those aren't 7.5" wide? You know, you are supposed to measure from bead surface to bead surface, not outer rim dimensions.
Hey guys, remember, as the sidewall gets shorter, the angle of the sidewall becomes greater, when you have differences in tire and rim width. Theoretically, if you have a 295 MM width tire, it would fit on a 7.5" wide rim, if the sidewall was high enough.
