I know about the KA... I'm not telling anyone in my area I'm getting a CA18. They'll find out soon enough
. Anyhow, it took a lot of work to do. Basically we had to take all the sheet metal from my 240 off, chop out the mounts for the headlights... actually take out most of the bumper support, make custom brackets and mounts, line everything up using shims and such, use rubber stops to keep the hood even, took 9 hours to install, we've done another 3 hours lining the front end up, and we're tucking the fenders in a little more... not too much, I have rear fender flares to match it. I went with the GTS because, 1) it's all I could find, 2) I have a RWD car, the GTS is RWD, and 3) there is no 3. I could probably just get a GTR grill and hood and I'd be fine, everything else is the same. Same fenders, head lights, etc. etc. I actually like the GTS corners more, they're clear with amber inserts, rather then just all amber. Anyhow, I'm not done with it yet, it's a slow project... lack of funds. If you guys want to donate to the Sky Eighty fund, you're more then welcome
