speedeast »
https://forums.nicoclub.com/speedeast-u139789.html
Thu Feb 11, 2010 7:37 pm
First, take the spark plug out of cylinder #1. Then place a finger or hand over the hole. Manually turn the crank until you FEEL the end of the compression stroke. It will push air out of the hole on the compression stroke. When it seizes to push air, that is TDC. Replace spark plug. From that point, make sure that your ignition rotor is correct and that all of your spark plug wires are correct as well. Check all of your fuses, etc etc etc. When you think you're ready, turn the key to accessory and make sure you can tell that the fuel pump is priming (just a precautionary measure) then try to crank her up.
Good luck dude and keep us in the loop.
