I only hear a single relay click. The car runs for ever once I get it started. I drove it 38 miles home after I got it pushed started the other day. And now If I run 12 volt directly to the starter it starts on command. So it has to be wiring or a bad relay some where.goldfish wrote:What noises if any does the car make when you attempt to start it? Do you hear clicking? Do you only hear the fuel pump priming? After push starting, how long can you run the car for? Have you tested your battery? More info
