BRADYNS240SX »
https://forums.nicoclub.com/bradyns240sx-u52267.html
Mon Dec 18, 2006 3:23 am
My 89 240 just had the engine swapped over to the SR20. Stock turbo, only other mods are exhaust. I have a little over 1,500 miles on the swap. I installed a Boost controller, and gauge and have been having problems since. When car is idleing the boost gauge reads 5psi. When I get into the throttle it jumps up to 14 psi and then drop's down to 12psi instantly. Also went to start the car the other day and did not want to even start. Finally got is started and the car is hesitating when I get in the throttle. Can someone give me so ideas on what to try out to get this fixed? The timing is dead on. Not sure what else it could be.
