240sx with compression ratio of 8:1???
WORKS89
Car: EVO VIII GSR, 07' Versa 6spd, AND 92' Z32
So a buddy of mine just picked up a KA motor that has all the internals and block modified to run a Turbo. It has a compression ratio of 8:1. My friend wants to run it as a NA stock motor though. He's installing the stock ECU and everything, but leaving the internals how they are. Wont the car run bad because the car is suppose to run at about 9.5:1. He claims the car will make 200whp? Wondering what you guy think?
WORKS89
someones got to have the answer to this.
needmorenissan
Car: 1993 Nissan 240sx and to much to handle
not even with stock compression it will run 200 whp
WORKS89
I got a answer off 240sx forums:
the HP will be lower than stock... Less compression...
It may be a bit of a dog too...
Guessing HP numbers is worthless... it is like dyno numbers.. it is just a number...
Bottom line, the engine will not have the same output as a stock, 9.5:1 engine
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
lower compression = lower hp
what do you think turboing a motor does?
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
Get a new friend that understands engine dynamics first, then you have to realize that it costs a lot of money to make a 200whp na ka or about $1500 to make a reliable 300 whp ka-t. Remember that that high compression and high displacement are the only ways to make NA power. That is all.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
spanks got it...but if id were you..id talk your buddy out of that block and get it for your self..it definitly has after market pistons at least..if not rods and studs too!..then turbo that bi-o-tch..and laugh all the way to the bank!..just my opion
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
Hey atleast with those 8:1 compression the ka24de will drive great on 87OCTANE. No need for supreme.
Thats the only advantage I see from that compression.
WORKS89
Bigvinnie wrote:Hey atleast with those 8:1 compression the ka24de will drive great on 87OCTANE. No need for supreme.
nice!
