I've heard of that many times. But I was unable to find ANY information on how to do it, other than you need the block off plate. That's all I could find.Josh@NSP wrote:You can remove the egr system, I remove it on many of the swaps I do. Car will run the same and wont even flash a cel if you block everything off properly.
reeeeeeeeeeeally. you couldnt find ANY info.todd5854 wrote:I've heard of that many times. But I was unable to find ANY information on how to do it, other than you need the block off plate. That's all I could find.
todd5854 wrote:Also, it will fail visual inspection in PA I believe. I could be wrong.
todd5854 wrote: I could be wrong.
todd5854 wrote: wrong.
