240sx Water Pump Gasket...?
StryfeS13
Car: 1993 Nissan 240SX
Is there a gasket for this? I removed it from my block(rebuilding)and wasnt able to tell if it is liquid gasket or a real gasket.
Can I use liquid gasket to seal it? And if so, which liquid gasket? Blue RTV?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
It uses silicone sealer.I use Permatex Ultra Grey.Don't use blue s**t.
StryfeS13
Thanks a lot man. What about the oil pan? Real gasket or silicone?
sx moneypit
1986 Toyota MR2
Silicone gasket maker.
boost240
Car: 89 240sx with sr20det
second him on the water pump not oil pan i found one not hard at all alot easier imo.
sx moneypit
1986 Toyota MR2
If you are dealing with the oil pan with the engine in the car,a gasket is easier to work with. If the engine is out i prefer to use sealer unless the OEM specifies otherwise.
