i got the typical s13 hatch harness bar, thinking it might fit in between the verts large interior panels.... man was i wrong..
the bars main problem was how far back it went, and the angles it was intended for.. i already had the bar, so i busted out the saw and welder, and cut the ends of the bar down about 6" shorter, and re-welded at a bit more agressive angle... and now it mounts on the oem lower seatbelt bolt hole, and the top mounts to the thick metal door retainer bracket. overall it sits about an inch higher than the back of the s14 seat... i can still fully scoot my seat back, and recline it enough that i cant reach the steering wheel..
pictures were a little hard to get in the dark in my garage, but it is pretty easy to fit.. also kind of interesting that the bar is a 2.5" diameter and is schedule 40 steel... i was pretty happy about that!
this is whats sitting in the engine bay of the vert...
there is no doubt about how tough this bar is, im a really husky guy at over 6'0 300 lbs, i stood and jumped on it and had no flex or movement at all.. the only movement was the car rocking left to right.
I could definitely recommend this to anyone who doesn't want to eliminate their back seats, but wants to utilize harness's properly..
