240sx troubles
blind.i
Car: 1996 Nissan 249sx
ok i need help i have a 96 240sx with no work done to it and i been having problems with my battery. it dies out extremely fast i could get a new one and it die the next day. the alternator is still good. can anyone help me?
pmkls2
Car: 1990 240SX Fastback
Are you sure of the condition of the alternator ? If the alternator is charging and you aren't leaving an electrical component on then the only thing left is there is a parasitic battery draw draining the battery. I'm a GM tech so I don't have any suggestions on what may be causing the draw. All you need to test for a draw is a digital multimeter capable of reading amperage and some type of battery disconnect.
blind.i
i been told it could be a short but i dont know where to start with that. i also been told i could get a cut off switch for my battery, but that would only help for a bit. would that help to get me by till i can fix the real problem? its really my only means of transportation.
Logan76
Car: Junk
I would say you could just pull the connections off your battery every night, until you find out whats wrong. just an idea.
Scoutz
Car: 95 240sx SE
lol, sounds like you have the same problem i had. go check the wire that is running from the alternator to the fuse box. it requires a 14mm wrench or deep socket to tighten. If the fuse box wire is not loose, then go to the alternator, and make sure that the black (ground) wire did not break or have corrision(white powder) all over it. Make sure the power cable is and the black wires are both tightened. Hope that helps.
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
I would start with Scoutz idea but how are you sure your altenator is good? Have you tested it? I have seen them start to go bad and just not put out the proper volts and slowly kill the battery. If it's dying overnight it sounds like the battery is drawing from a ground. Unless something stupid is going on like your interior lights staying on etc. I assume you would notice that however. Something I have noticed with my 240 is the battery terminal connectors are messed up and if they go loose the battery acts like it's dead but you can go wiggle the wires and it will regain power. I have just been to busy to put new ones on it. So I would check them while your at it as well.
mexicanracer03
Car: 95 S15FRONTEND SR20DET and 97 2JZ GT4294/ 93 SC300 Black/ 95 SC300 Green
Take the Alt. off and go to your local auto store and have them test it.
blind.i
i have taken it in to be tested and they tested it four times and it came up good and each test.
mexicanracer03
have you taken the battery to get tested ?
blind.i
right now the battery is dead. its been awhile since i ben able to work on it. i looked under it and the clip that goes to the alternator was disconnected and i know i made sure i connected it last time. what would that do?
blind.i
the clip is not clipping in it goes in but it also slides right out.
mexicanracer03
you can use a drop of Super Glue to hold the clip in the alt.
also if you battery is no good it will make the alt. work Overtime and eventualy cause it to burn out.
then you not only will need a battery but and alt. aswell. GL
blind.i
it looks like im gonna have to change out both. but thanks for all your help everyone
