240sx transmission swap
Patarach
Car: 240sx convertible KA-T
Ok well I looked everywhere but I can't find my answer, but I did a transmission swap to my 240sx vert and i was wondering if the top will still function with a manual ecu, or if the auto ecu makes it work, I am just wondering because my check engine light is annoying me and I have emissions soon.... Thank you
Hijacker
Car: '92 240sx Convertible
'94 F-150
The ATCU completes the top circuit, not the ECU. However, there's a wire than can be jumped on the back of the top up/down switch that will bypass the ecu.
If you're CEL is on, I would suggest pulling codes to see what the problem is
Patarach
Feels good to get an answer from you but I am still pretty lost, I don't really know the electrical systems very well. I though my engine light was on because of the swap, and thats the only reason I wasnted to change the ecu in the first place because i thought that is what turned it off..
madcowCONV
Car: 240sx convertibel
if you have a check engine ligh its not from the sawp only s14's give you a CEL when you change fron auto to 5spd. Like said above get a FSM and check the codes
Patarach wrote:Feels good to get an answer from you but I am still pretty lost, I don't really know the electrical systems very well. I though my engine light was on because of the swap, and thats the only reason I wasnted to change the ecu in the first place because i thought that is what turned it off..
Patarach
well now that I know that it is actually not the transmission wiring i am relieved, I can fix everything else. Thank you guys
Hijacker
'94 F-150
I'll save you a bit of trouble for looking
http://www.240sx.org/faq/artic...h.htm
That's an article to set your ecu for pulling codes, how to read them, and decipher which code means what.
The article says it's for 95-98, but all the codes match up to about 105. ODBI ECUs shouldn't pull A/T codes. The opnly code missing off that list is '55', which stands for all clear
