240sx toe rods
giodachamp
Car: Nissan 240SX S13 (180SX)
I tried searching but came up empty. Is the 300zx rear toe arms compatible with s13? The reason why I'm asking is because my friend is selling his aftermarket 300zx rear toe arm to me for hella cheap. Thanks
Modified by giodachamp at 12:57 PM 10/24/2009
Bumnah
Car: 1992 240SX, black. Bone stock.
Are you talking about inner or outer tie rods?
Outer tie rods are not compatible. I believe the taper is different on the 300zx outer tie rods, and they don't work with the 240sx knuckles.
Using OEM 300zx inner tie rods is an upgrade to the 240sx setup. The 300zx inner tie rods are thicker, and you retain the factory lock pin, but they require the use of SPL outer tie rods. SPL outer tie rods aren't the cheapest, they certainly one of the best, if not, the best.
giodachamp
I'm sorry for the confussion. I was talking about the rear toe arm not the tie rods.
