evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Feb 03, 2008 10:22 am
I think you are using some incorrect terms, as far as I knwo all spindles? (guessing you mean stub axles?) are steel, the LCA's I thought were alumnum on all Z32's, as for the diff, the Z32TT uses an R230 VSLD and the Z32 n/a uses an R200VLSD, if you want the R200VLSD you it should mount to your rear subframs as the stocker did but will require CV shafts and companion flanges form the Z32N/A, you might have to swap your stock pinion flange ofver to fit your driveshaft as they are both short snout R200's they might be the same?
