AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Thu Aug 04, 2005 3:27 pm
Contrary to common opinion, while there is *some* increase to be gained by a wider tire, it is not even CLOSE to a 1:1 ratio. In other words, doubling the width does NOT double the contact patch. Matter of fact, it's actually pretty minimal (if kept within the restraints of a practical "+2 or +3" fitment). "Ricer math" is a *****.
*Assuming equal weight (load) and equal air pressure, sidewall stiffness, small differences in tire weight, all that crap... A wider tire will deflect from front to rear LESS than a narrow tire.
If you were to park your car on a piece of glass and look at it from beneath with 195/65/15's and 275/40/17's, and measure the surface area (assuming * above) of each contact patch (disregarding tread voids), they'd be remarkably similar in area.
A narrower tire's contact patch will be long (front to back) and narrow (side to side). A wider tire's contact patch will be shorter (front to back) and wider (side to side). Keep in mind, the weight is distributed the same over both tires.
It's pretty hard for most people to comprehend, so take it to the extreme: Put your car on a set of 44" monster truck tires (with no "tread lugs"). Your car will not have sufficient weight to distort the patch, therefore the patch will look like a pencil perpendicular to the direction of travel. Put the same car on some 155/80/13's, and it will distort the contact patch into a narrow shape parallel to the direction of travel.
There IS a "sweet spot" in tire sizing, at which point the negatives (increased rolling resistance due to deformation of a wider tread, increased weight and increased ground-to-tire interface friction) are superceded by the positives (better contact patch "shape" - rectangular rather than oval, more predictable breakaway at the limit and better sidewall stiffness.
Contact patch SHAPE is far more important than SIZE, and the 295mm wide tire will result in a contact patch that is more conducive to lateral adhesion (and a far more linear loss of adhesion).
To an extreme, a 335/20 would theoretically be an even bigger improvement on the track (or maybe a full rubber cylinder stretching the width of the car like a steamroller), which we know not to be true.
Most people are terribly guilty of equating GRIP with SPEED, which is NOT definitively the case.
Read that again, and let it sink in. You can have PHENOMENAL grip in a corner and still go slower. Again, take it to the extreme: 335mm wide tires, made of hyper-sticky compound, will be SLOWER through a corner (and the straights) than a 245mm tire designed for track performance. There comes a point when the tire width is actually a DETRIMENT.
The gains are not linear, they are not limitless and they actually resemble a bell-shaped curve (which you're familiar with from statistics).
Wider tires generate a more gentle breakaway. They eat up horsepower and momentum doing it, but the margin of safety is greater. A narrower, harder tire will be nimble, but you'll get little warning when it's about to get away from you.
Again, you CAN'T argue with the picture I posted - it's obvious that the sizes are the same. That's not hard to accept. The patch size hasn't changed noticeably.
Even when you DO achieve a bigger patch, by extreme increases in section width, PRESSURE, in pounds per square inch, that the tire applies to the track surface decreases.
----->Imagine if you had to wear 6" stiletto heels vs a pair of Nike Air Trainers. How much of your weight would be concentrated on that heel? Would you agree that the heel is pretty firmly planted into the surface? Would you agree that it's harder to move that heel laterally? Would you agree that if / when it DOES move, it will do so violently and with less warning? Not so with the Nike. It will be predictable and manageable - which is where your skill as a driver is enhanced. Would you prefer that Nike to be twice or three times it's width? Nope. There's a sweet spot for performance.
Keep in mind if wider ALWAYS AND UNEQUIVOCALLY meant better, NASCAR / F1 / Indy would be running monster widths. They're not. They've found the "sweet spot".on the bell curve, the "sweet spot" for tire width is at the peak (with coefficient of friction, lap times, whatever on the y axis).
Too wide, and speed suffers. Too narrow, speed suffers. Different reasons, same outcome.
