So he is on the part where he has to put the upper and lower timing chains on, and do the timing. Something is not right and we can't figure out what it is. The lower timing chain is on...and everything appears to be at TDC, using the screwdriver method. The exhaust dowel is at a 90 degree angle pointing upward...and the intake dowel is slightly to the left. The lobes on both cams are pointing outward. We have been using Jim Wolf's guide for installing cams...as well as various you tube videos, and the Chilton Manuel. The thing is...no matter what we do...the upper timing chain will not go on.
I posted some pics...any ideas of what may be going on? or if we are doing something wrong?
Edit: *This is for 1991 Nissan 240sx KA24de*
