mambastu wrote:Not sure how necessary it is to buy another tacho tbh.
I've been fiddling with the tacho on my 91 eurospec S13 today. Managed to get it to read correctly by following GTRShops advice on another thread.
I fitted a 10k resistor between the ign and signal screws on the circuitboard on the back of the tacho. The tacho then started reading the signal from the ECU and was approximately double the actual figure. Removed the tacho from the cluster and adjusted the variable resistor (accessible from the back of the tacho) anticlockwise as far as it goes.
Put it all back together and its now pretty accurate, probably more accurate than it was originally with the CA
Just got to sort the speedo out now![]()
DETurbine wrote:I just did it to mine last night and it works perfectly. Keep in mind that you need to use the DOHC cluster and you need to turn the variable resistor clockwise as far as it will go not counter-clockwise.......it is pretty dead on and is only $0.20 for the 1/2 watt 10k ohm resistor that you can pick up at any radioshack.
All I have to say is screw McKinney and LSAutomotive for trying and selling them for $100.....when you can do it for $0.20 and takes 20min to take out, do, and then put back in.
dareo wrote:Can't you just remove the 240sx tach and replace it with a 6 cylinder DOHC nissan tach from a 300zx or maxima? I know i read that somewhere, on the internet even, so it has to be true!
frosted flakes wrote:I just checked the accuracy of the tach with the variable resistor turned fully clockwise.
When my tach reads:-900rpm(idle) the actual rpm is 850rpm (from the apexi s-afc2) -3,000rpm the actual rpm 2,850rpm
I did not rev it up anyhigher because it is in my garage but the tach with the calibration is pretty accurate now, with the resistor turned fully CLOCKWISE.
