240sx
danpar69
Car: nissan 240sx
car starts and idles fine but when i give it gas it runs or sounds like it is out of gas if i feather the throttle it seems to go ok but not like it did when i got it .......help have trip to ark on the 1st need to get it figured out before
danpar69
Car: nissan 240sx
danpar69 wrote:car starts and idles fine but when i give it gas it runs or sounds like it is out of gas if i feather the throttle it seems to go ok but not like it did when i got it .......help have trip to ark on the 1st need to get it figured out before
have a full tank and new fuel filter and never quites
dfddfd2
Car: 240sx
Sounds like throttle position sensor (TPS). Check ECU for diagnostic codes (DTCs).
ls1240
Car: 1990 240sx hatch
my car is doing the same thing its running rich does your cars exhaust have black smoke whe u gas it? well check your vaccum lines and fuel pressure regulater and injector seals mine has a leak in it i have to buy new seals or o rings
