240sx Swaps SR20DET vs. RB25DET
UndftdSole
Car: 90' 240sx RB25DET, 07 Subaru WRX
im assuming you have an s13? doing a swap you must do all the wirings and such. that will be time consuming. also most of the problems after the rb25 swaps in s13 chassis are either tach or speedo doesnt work or even both. you must do a lot. if you dedicated into swapping rb25 in your s13, be sure you have lots of funds and patience. thats my .02 cents
S14toRPS13
teamelude wrote:The key is I want a pretty much stock engine with power thats why I am thinking of choosing the 25. Yes I know I will be needing brakes and a suspension set up but I dont plan to be driving crazily at the beginning because I want to learn how to react to the heavy nose.
For the money you'll be spending on a stock RB25 swap, you can have a SR or KA-T with more power output than the stock RB25. As long as you get a good ecu tune for your motor, it'll be just as reliable as stock and probably have better gas mileage than the RB25. I spent $4400 on my SR swap and was able to put out 270 whp. If having a RB is really important to you, then yes, I'd say it's worth the money. But I if you're just looking at the 220 to 250 whp, the SR and KA-T's are better bangs for the buck.
Modified by S14toRPS13 at 6:19 AM 1/31/2009
Romeo_rus
Car: zenki RB25DET - SOLD, zenki SE ka24de - wrecked, zenki - sold, GOLD ZENKI - WILL LIVE FOREVA
teamelude wrote:Alright I have to save up a little longer but I want to make sure that I can have all the parts and even the maintenence parts that need to be replaced to prevent future problems and costs but I was thinking Front Clip 2600Mounts depends on producer 350 - 550Harness depends on who will do it 450Radiator 100-400Electric Fans 50-350Timing Belt 140Clutch 160Flywheel Water Pump 70(stock) - 265 N1Plumbing Lines Driveshaft 305 shaftsmastersAnd if anyone could else name parts that I would need so I can get a close estimate than save a grand over that
Romeo_rus
I would add front pump seal and rear main seal
Bmxandcars
Car: '92 240sx hatch
vh45de
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
yeah,,,but OP thinks that KA-T is unreliable! You just have to know what you're doing.
teamelude
Car: 1993 240sx Nissan
Thanks yeah I think the RB25 might be too far out of reach right now I think I might go SR sorry for changing my mind so many times I was just thinking about how I heard that the SR20 gives the car good balance seeing that it is lighter also I don't plan on messing with the engine and knowing that the aftermarket is huge on those motors I think that is what finally got me to make my mind.Thanks appreciate it.
cali0240
Car: Nissan 240sx 1995 s14
teamelude wrote:Thanks yeah I think the RB25 might be too far out of reach right now I think I might go SR sorry for changing my mind so many times I was just thinking about how I heard that the SR20 gives the car good balance seeing that it is lighter also I don't plan on messing with the engine and knowing that the aftermarket is huge on those motors I think that is what finally got me to make my mind.Thanks appreciate it.
so what exactly did u end up doing??? sr20 or rb?
Hoffman5982
Car: '95 sr20det 240sx
Romeo_rus wrote:I'm doing rb25det swap into my s14 right now... I've spent so farmounts 250mount bushings 80fmic 105swap 2000harness 358driveshaft 305
and it looks cheaper than SR20det (on ebay) 3200+ swap
what mounts did you use and how good are they. I was going to go with McKinney but 250 sounds better than 450
da** this thread is old
sOhcS_13
Car: 1990 S13
ca18det ftw!! i know this wasnt one of the choices but its a great swap choice...check into it
