Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Aug 12, 2008 6:40 am
You don't need to remove the dash.
Unbolt the ECU connector and the connector going to the dash. If you have an automatic, you'll need to disconnect the harness from the auto computer. It's located above the ECU.
If you ahve a friend, have them pull the harness through the firewall while you guide the harness around the blower motor. Take your time as you can rip/cut wires on accident especially if the harness gets snagged and you or your friend are the impatient type.
You can do it by yourself, but expect to be doing a lot of back and forth from the footwell to the engine bay.
