Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Fri Mar 18, 2005 10:08 pm
Long story short: check the sensor at the rear of the transmition,and try another shop who specializes in transmition work. it could be something as simple as the speed sensor for the output of the transmition....
more info:Im not sure how Nissan autos work but trannys that dont use electronics for everything have something called a govener, wich produces hydrualic pressure that is ruffly equivalant to the speed of the vehichle. The transmition balances this pressure against the hydrolic pressure of another device called a throttle valve(T.V.). T.V. makes pressure equivalant to the load on the engine(or throttle position). These two pressures operateon opposite sides of a valve in the transmition, and when the pressure from the govener(vehichle speed) overcomes T.V. pressure(throttle position) the vehicle shifts. Basicly this is so if your are on the trottle hard, it takes more speed for an upshift, or will downshift if speed is low enough. But if the govener isnt working right it wont know how fast the vehichle is going so it wont shift untill it very late, like yours. It looks like the 240's auto uses more electronics then the one I work on(Just finished with a class on auto trannys) and I could find a govener when I looked thru the FSM so im pretty sure its just that sensor in its place.
It could also be other things as well so you could need a new one, but alot of shops dont see alot of auto transmission work, so when they do they have little experiance/specialized tools/VERY CLEAN facilitys and are quick to recomend a replacement.
