yea i know, but the inserts goes in the old bushings. its stiffens it up. plus if i would use the collars would make it even better? am i right?maj Andres wrote:If you want to replace the 4 subframe bushings then you must drop the subframe. The collars are used to clean up the slop from the old bushings, no need to use both. You could, but what's the point? Notice how half of the subcollars are slotted? that's so you wouldn't have to drop the subframe.
Check out the install zerothread/97924
What are these????
