Altiman94 wrote:engine grounds?
i agree with altiman, i had very small stumble problems when i first got my car. new engine grounds cleared it up, one of the biggest problems with the 240sx grounds from my experience are:
1. rear engine to chassis ground, this is a real flimsy wire and it's often corroded, sometimes completely gone on high mileage cars. it goes from the corner of the valve cover to the firewall right under the brake lines coming from the master cylinder (right side if your looking from the front of the car)
2. the chassis to battery ground often gets corroded. basically the line from the engine goes to the battery tray (chassis ground point) then to the battery terminal. the ground is just a 2" section of exposed copper wire crimped against a bolted bracket. I highlighted that because if you have ever seen the statue of liberty or a copper shingled roof you know what happens to copper exposed to the elements.
those are your two main colprits, but also check your MAS ground, it is very important it gets a clean ground or the readings will be skewed.
I also might add that i have very slight power dip at about 2600rpm, redoing the engine grounds helped but i never could get rid of it. Its small that people riding with you wont notice it, but if you drive the car everyday youll notice. This probably isnt your problem but might as well state as much relavent info as possible.
