240sx sputtering!!!!!!!!!!!!!HELP ASAP! have to fix for work!!!
hakosuka86
Car: Toyotas Nissans
hii had sum heating problems and when i though i had it all fixed drove to work no problem 30 mins.
still i think i need to make sure i have no bubbles on the system.------------------------\
so i came out 7 hours after go in the car turn it onand it started rough and it was sputtering i let it warm up thinking it was too colddrove off after and its was sputtering quite noticible
I made it home I swap to new spark plugs and fuel filter!drove around but still the same problem
ideas i have are:
dirty maf? really?bad timing?cold start plug went bad?
but i cant just spend money like crazy because im not in that position right now. i just need it fixed i have work tomorrow Thank you!!!!!
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
clean your maf, check and make sure your TB is clear from carbon........
if those dont correct it, check for vac leaks
could be your FP dying, timing, dirty injectors, air filter, fuel filter, or any number off things.
the first 3 mentioned are cheap or free to fix
kpodj61240
Car: S14 Zenki
yea i would go with cleaning ur mass air and checking for vac leaks like ca18detgabby said
hakosuka86
thanx guys i shall do that!
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
also how old is the fuel filter?
hakosuka86
well I changed that also,and i checked for vaccum leaks 2 times and pretty much everything its connected right.
I also sprayed and cleaned the maf with brake cleaner it felt better but the problem still there.
I would have to lean more to this being an injector not working properly.
