what he said. unless you plan on modding it VERY slowly considering your in school and only 15. no disresepect or offense but do you have a job to afford modifying the car? also fixing/fabricating broken parts considering its gonna be used for drifting?NismoZRS wrote:lol school and cars dont mix... ever..
thanks for the supportAAV240sx wrote:Get your driver's license first, buy a random used car to learn on, focus on school and don't worry about building a drift car?
alright, that helps.what do you recomend or what do you have coilover wise?ILoveMyRHS13 wrote:Okay, lets have a down to earth moment here. I'm 18 now. I got my 240 when I was 16; I thought I was hot s*** when I got it. I wanted to have an uber JDM drift car right out of the box. The truth is, real parts are NOT cheap. My advice, weld your diff, get coilovers and go to a track. You can drift the hell out of a stock motor all day long. I've had my car for two years and I am just now getting to that stage. I focused most of my time and money into school and my social life. Now that I'm out of school and working full time I can really get to work on the car.
Hope this helps.
PS- Don't buy garbage coilovers like KSport, Megan, D2 or Godspeed.
knuckle kit=as in angle kit, shortens steering ratio as well as adds around 15 degrees more into your steering left or right.and this does help but, how old are you? did you get professional help or somthin or did you just come up with this on your own? im not to judge but you sound like you either know exactly what your talkin about or your tryin to act like you have been drifting for 10 years... just sayinAZ89two4Tsx wrote:Try driving it first. Oh wait, you don't even have it yet?
You'll never be able to take full advantage of performance parts if you don't do without them first.
I'll go down the list and give you my opinion on these.
Coils - Yes, get some eventually. They don't have to be K-Sports though
Camber kit - There's different brands, not really necessary unless you have baller wheels, track car, etc...
Sway bars - If you're going to "drift" it, you won't even want a rear sway bar. Again, do without first.
Knuckle kit - Do you even know what that does?
Rotors/Pads - If they need to be replaced, whatever, but still, just get oem stuff.
Bushings - Yeah, if yours are worn, sure. Shouldn't be a huge priority.
Cams - Maybe, but drive it stock first for a while.
Intake - Soooooooo overated. Keep yours stock. At the most put a cone filter on it and leave it alone.
Header - There's only one manifold not two. Again, drive it for a while.
Exhaust - Yeah sure, just keep it around 2.5" No need for 3" unless you have some kind of forced induction.
Clutch - Not really any need for a performance clutch. Just go oem if the engine is stock, unless it's a track car?
Flywheel/Shifter - Drive the car first
Ignition - Again, would you even know the advantage of that/how to go about doing it?
Welded diff - Sure if you can stand the weird looks you get in a parking lot.
I sound like a ricer. My advice is, drive the car first. Quit getting ahead of yourself. There will be sooo many things you'll have to do maintenance wise or something else before you start spending money on upgrades.
You'll see. I sure did.....am.
AZ89two4Tsx wrote:Look at my profile.
All I'm trying to say is DRIVE THE CAR FIRST. Don't get ahead of yourself. You'll realize once you start driving the car, that that's all you want to do, drive it. Worry about all that stuff later. Go out there and enjoy it before you start tearing it up. Who knows, you might change your mind.
Besides, do you have any money saved up? Have you factored in gas, insurance, maintenance? What about the interior? Is this going to be a track slut? Most 240 interiors are beat to s***. Do you have the tools to install all these mods? How would you pull the differential? Do you have air tools? A compressor? A lift? Torque wrench?
You can't just be working with a basic Tonka tool kit you got for $10 at the Target clearance rack.
Ok... here's you you should do:stnapyxes wrote: i got 3 friends that are planning to do almost the same as i am
