ya replace the ignition switch. you dont need to replace the ignition module though. just the electronic piece.dsilvia89 wrote:hey everyone, i just picked up a 95 240sx for 800 bucks to be my winter/daily. mint car , the only thing wrong with it is the ignition is a pain in the a**! it literally starts everytime its just the key has to be in a veeeeery specific spot. any insight on this? The only thing i could think of is change the ignition module...
thanks for any help!
i have never seen them with the heads still attached, have you? you can also use left handed drill bits to remove the bolts holding the ignition on the column.pj wrote: if you are licky the bolt heads will still be attached to the bolt and itll be easy to remove as well.
yeah, well there was no way i was going to walk to the parts house n buy a left hand bit. and pretty much i just did a incredible hulk rage and went to its a** with a saw loldsilvia89 wrote: pj the hacksw was uneccesary lol
well, yes and no, ive done it twice. this time there were none left, last time there was 1. i took that one out and just bent its a** over until it broke the other clasp or whatever. so that was easier.motoman399 wrote:i have never seen them with the heads still attached, have you?.
