240sx s14 Apexi ExV N1 coilover damper settings?
palooza73
Car: 1998 nisaan 240sx LE
Hey guys whats up? I have a new set of Exv's from Apexi, and i was wondering if you guys happen to know the stock damper settings that was preset from the factory? My little basterd cousin started messing with the knobs when I wasnt home. thanks!!
McRussellPants
Car: 92 240SX
It doesn't matter... at all.
Just put them on the softest setting and turn them up as you see fit.
palooza73
yes i understend that. but i want to know what Apex suggests to use. They have done the R&D on this and reccomnd this setting from the factory. I just want to know.
naed240sx
Car: .....
palooza73 wrote:yes i understend that. but i want to know what Apex suggests to use. They have done the R&D on this and reccomnd this setting from the factory. I just want to know.
There is no reccomended setting. It all depends on what wheels tires,links, sways, etc you are running. The dampers are adjustable for you to fine tune handling. Find where YOU like it best.
c32c7
Car: Kouki S14
what he said, also, recommended damper settings are dictated by the track you're driving on. or street.
palooza73
yes i understand what you guys are trying to say. but my car completly stock except for the coilovers. And i just want a good starting point.
naed240sx
Car: .....
palooza73 wrote:yes i understand what you guys are trying to say. but my car completly stock except for the coilovers. And i just want a good starting point.
A good starting point is the softest setting on the dampers. If it feels bouncy, go up a click or two. If it is still bouncy, then go up further. Done. There is NO baseline that the companies give out.
palooza73
then why arent they set at the softest from the factory?
naed240sx
Car: .....
palooza73 wrote:then why arent they set at the softest from the factory?
umm i dunno man. Sorry, but you are probably like the only person to ever ask this question. You are supposed to tune them to your settings.
