240sx S13 Rear ball joint install......
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
So today my car was at the shop and i was there helpin out as usual and we were doin the back RS*R bushings including the LCA bushings and all the spindle bushings... As well as the B13 93' sentra ball joints in the rear LCA's well everything was going pretty smooth and the sleeves in the spindle and LCA's are a huge pain in the *** to do but one side is complete as of now.. WELL bushing wise at least.
We got to installing the sentra ball joints and they do not fit in the lca... They look like they would but they do not.. we were usin a hammer and a socket around the ball joint so it wouldnt damage it and it will not go in at all..... So my question is why have these worked for other people? What did you do to make them fit... And are the front lca ball joints the same as the rear lca ball joints?
OM3GA
bump AHH need answers by tomorrow
dsc4130
have you tried a ball joint press? there not going to go in that easy thats why they stay there for 15 year at a time, go to autozone, rent one and do it the right way. might i ask why the b13 ball joint, why not a stock one?
574-240sx
Car: Nissans, Toyotas, Subaru
They don't sell just the rear ball joint for the S13, you have to by the whole lower control arm. The S13 sentra ball joint is a close fit, you have grind/file it down to fit.
dsc4130
574-240sx wrote:They don't sell just the rear ball joint for the S13, you have to by the whole lower control arm. The S13 sentra ball joint is a close fit, you have grind/file it down to fit.
ok gotcha there did not konw that, havent had to do it yet. good luck with that
OM3GA
Do the s13 front ball joints fit in the rear?
supersayianjim
Car: 89 240sx(s13)
i would like to also know if this is true or not???^^
Bumnah
Car: 1992 240SX, black. Bone stock.
front and rear ball joints are different. you can't use the front on the rear.
the sentra ball joint will work. the difference is only .5mm.
getting them out will not be easy.
i had a shop do my balljoints, so i can't give you any tips on how to do the swap
but they work, that's what i'm using.
ghx407
Car: 1993 240SX KA-T
I installed front ball joints for an '89 Sentra in my S13's rear LCAs. I left them in the freezer for about a day, and used an AutoZone ball-joint press and a little grease. They went in like butter.
barefoot mat
Car: twin cam s13 fastback
sooooooooooo......
what year sentra ball joints will work for the s13 rears? will i have to buy front or rear sentra ball joints? how much grinding would i have to do to get a clean fit?
i say this b/c im about to tear the rear suspension apart for energy bushing install.
gigabit240
Car: 92 s13 hatch -sold
98 s14 kouki -current
lube it up lolz
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
barefoot mat wrote:sooooooooooo......
read the post directly above yours.
motoman399
Car: 98' wrecked (RHD coming soon) 240
ghx407 wrote:I installed front ball joints for an '89 Sentra in my S13's rear LCAs. I left them in the freezer for about a day, and used an AutoZone ball-joint press and a little grease. They went in like butter.
I have used that trick before for a flywheel ring gear. Me and my dad flipped it around put the ring gear in the oven and the flywheel in the freezer slipped right on
xiaphin
Car: 10' Genesis Sedan 71' Datsun 510 90' S13 Fastback SR
I know OM3GA has figured this out since this thread was started in 2008... I just pressed in some MOOG K9509 in the front and MOOG K9633 in the rear. Theres another thread on here rear-ball-joint-replacement-s13-t345029.html with this response
Slappy wrote:I just pressed some MOOG 1989 Sentra front ball joints into my RLCAS and they fit like a glove.
Mine pressed in no problem, no freezing or grinding. You can see how I did it on my build page, link in sig. Also installed hyperflex bushings
Gabes13
Car: rb20det s13
xiaphin wrote:I know OM3GA has figured this out since this thread was started in 2008...
Lol
Lol
Lol
