240sx s13 max hp out of block and head?
Zlows13
Car: 1990 Nissan S13
I have a sohc engine and was wondering what was max hp I can get out of the stock block and head?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
The KA24 is a larger displacement four-cylinder motor. It was mainly built with low-end torque in mind. It also uses a long piston stroke to achieve its torque. This prevents it from having the high rev limit that is seen with other Nissan four-cylinder motors. With the basic bolt-ons, you can expect to see an additional 30 whp depending on the condition of your engine. Don't expect any huge horsepower gains from inexpensive NA modifications.
why would you even keep KA24E??? Get engine swap, go for KA24DE, SR's, RB's.
KA24E's are crap IMO. I'm rockin' my KA24E for now 'till I get a G, then swap that s*** out of there.
It's just not worth spending money on a KA24E......
Zlows13
Rogue One wrote:
Tue Sep 08, 2020 8:34 am
Was planning building engine so just wanted to know max hp I can push on the block
Zlows13
Also if I did swap to dohc how much hp could I expect to get out of that engine with stock internals? With a turbo set up
PapaSmurf2k3
Site Admin
Stock internals shouldn't be pushed past 300-350 whp, and that's with good injectors and supporting mods. Anything past that and you start running into issues with variation in supplied components (like micro-cracks and other grain-structure abnormalities in the rods/piston/block/cranks).
Zlows13
PapaSmurf2k3 wrote:
Tue Sep 08, 2020 11:31 pm
And this is one sohc or dohc?
PapaSmurf2k3
Site Admin
Both
Zlows13
PapaSmurf2k3 wrote:
Wed Sep 09, 2020 6:00 am
Both
Gotcha thanks
