240sx s13 LSD questions.. need help ! PLEASE FOR THE LOVE OF GOD!
dvs240
Hey everyone, I need help with a few questions I have about s13 JDm VLSD's. I just purchased one a day ago and I just noticed that it's for ABS when my 240sx is none Non-ABS. I'm wondering abou fitment, i really need to know because I bought it from a private seller. Also, if it would fit..is there any differences in size? dimensions? What fluid do i put in there? Which brands have you guys had luck with and what ratings? If you guys can help I would greatly appreciate it, thanks!
AznRide
Car: Cars, hondas, import cars, girls, cars, girls, girls, and more beautiful girls.
I doubt it would work, but don't take my word for it.
574-240sx
Car: Nissans, Toyotas, Subaru
I had a J30 vlsd that had an abs sensor. I just cut the wire so it wouldn't get in the way. It worked fine for me. Nick
rco8786
Ya man itll work fine. The driveshaft is telescoping so it changes length. you will need 5bolt axles tho
The Mic
Car: 3Z Wmb
call me ignorant, but from the factory the S13 240sx SE comes with vlsd or lsd or are they one in the same?
corn322
Car: 1993 240sx
vlsd = viscous limited slip differentiallsd = limited slip differential
some s13's had vlsd in them. the ones with ABS and hicas had it. and I think you don't need the 5 bolt axles, those where for s14. s13 had the 6 bolt (3 sets of 2)
randybunctious
Car: racing yo mama
yep corn322 is right i got the vlsd in my s13, i just unbolted the old turd and bolted the vlsd up, i used 80w gear oil. easy job
574-240sx
S13GUY wrote:call me ignorant, but from the factory the S13 240sx SE comes with vlsd or lsd or are they one in the same?
Only the hicas models came with lsd on the S13. I bought a 95 or 96 J30 vlsd and it had the 6 bolt flanges. Everything bolted up fine. Nick
SloS13
If Im not mistaken, older S13's also have a 5-bolt pattern
574-240sx
SloS13 wrote:If Im not mistaken, older S13's also have a 5-bolt pattern
None of my 240s have 5 bolt flanges. Nick
SloS13
Well, I just installed my VLSD on saturday. Definitly 5-bolt and it had S13 written on it. It could have been mislabeled I guess, but I've seen people on FA say that older ones have 5 bolt
Two-Forty
Hey nick, how hard was the j30 install. I read that the j30 pumpkin is about an inch longer?.....I found one and going to buy soon, but I wanna know for sure how the install is....please email me at [email protected]....thanks man
hannibal
Car: Red Line to Glenmont
Orion has a good wirte up on his sitehttp://www.ka24development.com
Jay
BuudWeizErr
S13's with VLSD were 5 bolt, S13's with open rear end had 6 bolt.
dima
Car: my wife, cars, linux
do not add any additives to your VLSD. It is a sealed unit.
Smurf6x6
Car: 93 CA18 Coupe
My S13 coupe came stock with a LSD (canadian). It has 6 bolt but then again I got ABS.
RatedR
Car: my beautiful young asian schoolgirl wife! Hehehheheeh, yes, its a "field trip". Yeah, a &q
hey man, if you ever need help, just let me know. I had to swap out mine for a j30. VERY IMPRESSIVE~! I'm in Cali too, so dont hesitate to ask for help. hit me up here or on e-mail:[email protected]
574-240sx
Two-Forty wrote:Hey nick, how hard was the j30 install. I read that the j30 pumpkin is about an inch longer?.....I found one and going to buy soon, but I wanna know for sure how the install is....please email me at [email protected]....thanks man
Accually the J30 went in fine. I had to switch the rear covers. Then the stock bolts that go into the rear subframe weren't long enough. The bolts needed to be about an inch longer due to the bushings. I bought bolts at a specalty shop and had to have them machimed down to fit properly. Took a shop a day to machine correctly. I had about 2 days of down time. The drive shaft soaked up the extra length. Also I got the six bolt flanges with the J30. Hope this helps. Nick
