pr240sx »
https://forums.nicoclub.com/pr240sx-u5499.html
Mon Jun 21, 2004 5:13 am
Well, if you are replacing the hatch with one WITHOUT wiper harness, you can first use some wire to make the route, then, disassemble the harness (remove the plastic connectors) tape the cables to the wire, lube them (silicone grease or silicone spray works best) then start pulling SLOWLY. The easiest way is from the hatch towards the front (hatch removed of course) If stuck, start pulling back and forth. There is a "channel " inside the hatch for this. If you tape all the wires (making one, single fat wire) will be hard to bend where the glass meet the hatch deck.I tape it in intervals of 6 inches or so and went smooth and easy.
