240sx S13 Front-End Conversion to s15 (Help!)
PrettyBoy2142
Car: 1990 Nissan 240sx S13
Hey im nw to this forum and never relly used one before so ithought i try it. :)
I recentley bought a 190 240sx S13 Hatchback.
Im not really familiar with these cars, this will be the first one i will work on.
I bought the shell for $200 and they guy told me that he did a s15 front end convesion.
Im not sure how a s15 conversion looks like, so i need help identifying if it really is s15 conversion. :confused:
If it is not a s15 conversion, than what conversion is it? Did he even conver it to anything? :ohno:
Any help will be greatlyapprciated, i have big plans for this car.
If it definetley is thn i would like to make it look something like this vvv
What is that bumper called? Anyone?
Thans to everyone who can help :biggrin:
LuckyRps13
Car: 91 S13.5 240sx
i do not see any cuts to the radiator support for the head lights. and thefront top corners are untouched. so chances are he did not finish, or do the conversion. The car body looks stock at the moment, save the missing parts. but the picture of the white car you posted is the front end the seller was referring to. Try doing a google search, you may hear that alot on forums but almost any thing you can think of has been talked about before.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
these should tell you more about it.
http://www.nicoclub.com/archives/s13-s1 ... nders.html
S13, S14 240sx to S15 Silvia Conversion
Required Parts:
- Fenders, OEM or made for conversion
- Hood
- Lights and brackets
- Radiator Support
- Bumper
Procedure:
This requires extensive bodywork, even when using the fenders specially made for the conversion.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
The pic below is a S13 with an OEM S15 front end. Parts alone (OEM) ran over $2500 plus proper fabrication (no rigging), and paint.
OEM S14K/S15 Radiator support $300
OEM S13 and S14 tension rod brackets cut and welded together. S13 in the rear S14 in the front $125 plus welding
OEM S13 and OEM S15 fenders cut and welded toether and shaped $450-550 plus welding and body
OEM S15 hood $700
OEM S14 hood hinges $85.00
OEM S14 hood prop rod and gromet $65
OEM headlamps $675
OEM S15 bumper support (modified) $300
OEM S15 bumper $450
Wire harnesses $make yourself $35
Hood ornament $35
This is when I used CRAPPY RACEONUSA conversion parts I repeat they sell junk, and fiberglass is junk IMO
VS
OEM
