240sx's have two governors...damn
PabloHoney
Ok, so I unplugged my speed sensor and tried to do a top speed run on the local abandoned highway. My friend with an old cop car paced me (super accurate speedometer). So I get passed the normal 122 mph governor (I have a J30 rear end that is a 3.92 ratio rather than the 4.08, so the speedo is off a little). At about 129 indicated I hit a SECOND FUXING GOVERNOR. We figure that it is either: A). a 5th gear rev limiter or B). a 5th gear calculated speed governor to take over if the regular one doesn't work (sons o' bishez). Has anyone ever heard of this or read of it or anything?? Thanks.
S14aMike
I think there is a rev-limiter on 4th and 5th.
Night
Car: working on my car
there is a rev limiter in 4th at about redline and in 5th at 5000 rpms and the only way to get rid of it is new chip
PabloHoney
Night wrote:there is a rev limiter in 4th at about redline and in 5th at 5000 rpms and the only way to get rid of it is new chip
5000 isn't quite right. I hit it at about 5300-5350. Can you tell me where you got this information. I'd like to read a little more about it, and I haven't found anything on it. Thanks.
SWIFT_DRIFT
do the sr's have them in their transmission's too?
PabloHoney
Are you asking if they have a speed sensor in their transmission (yes they do) or if they have a governor (yes they also do at 112 mph, 180 km/h). The governor is built into the ECU though, not the speed sensor.
Night
PabloHoney wrote:5000 isn't quite right. I hit it at about 5300-5350. Can you tell me where you got this information. I'd like to read a little more about it, and I haven't found anything on it. Thanks.
5000 is right on my 93 the is when it kicks in every time in 5th
mainetc
Car: Driving fast, reading philosophy
I've never noticed what the RPM's were when my governor kicked in, but the speed was barely off the speedo at probably 110-115ish. I'll buy an ECU someday, but rarely do I drive that fast...
...THAT fast, that is.
Chris
240SXer
Car: 1995 240sx SE (2jz powered)
How did you unplug the speed sensor?
HyBriDThoErY
Wow, what is the top speed for the 1998 240sx's go? I had 147mph on my 2000 Celica. (sorry guys, I'm a newb to this forum)
Sygerwulf
Car: 91 240SX SE
I second 240SXer. Where is the damn thing? and can you just dissconnect it or do you need to cut a wire going into the ECU or what??
I rarely drive that fast too it would just make me feel better to know I can go alittle faster then 115mph : (
Sygerwulf
Car: 91 240SX SE
lol okay then, have any of you tried cutting the yellow wire with the green stripe?
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
The stock Tach can be off by over 600rpm's somtimes. I know I've seen 8k before and I was hitting a 7200rpm rev limiter.
The 4th and 5th gear both have lower rev limiters, you could always take off the gear sensor on the transmission (I think that's what I did, don't remember) and just have no reverse lights.
later,Paul
