omegahunterbass wrote:Well, other than the issue with the Frame rust, i have a couple other questions...First: How do i remove those?? (blue arrow)Second, Can I weld there (blue Arrow again) without removing the engine??
1st. Just pry them out with a flathead screwdriver, OR you can go under the tower and push them up so they will pop out.
2nd. I don't see how you would have to remove the engine to be able to weld there, so YES you can. Just remove the power steering reservoir and all the cables so you won't burn stuff. Also watch out for the relay box
