SloS13 »
https://forums.nicoclub.com/slos13-u1021.html
Sun Apr 16, 2006 6:30 am
1993 Nissan 240sx w/KA24DE
All emmissions stuff has been removed. Right now the only vaccum operated things are brake booster, FPR and secondary butterflies.
IdleCar starts and will idle great for a couple seconds then the idle will lower and it will start running very rough.
DrivingCar runs very smooth with very small throttle input, but as soon as you overstep a certain threshold of throttle opening, it will go into a mode of what feels like missing and retarded ignition, back your foot off a bit and voila it goes right back to smooth-runnign mode.
Compression is 180 across the boardI have also noticed that, when the car is idling bad, I can pull the #1 injector clip and it makes no difference whatsoever.
What I have tried replacing:Main engine harnessMain under-hood harness (From ECU to driver side floorboard)Sub-harness for IACV, etcIACVDistributor, cap, rotor buttonECUCoilfuel filterspark plugsMAFS
I NEED to get this thing running. Any help appreciated
