240sx ring and pinion gear on a q45 differential
bobob729
can this be done i want to keep the stock ratio with the q45 diff is that possible? i read somewhere else that it will just want to confirm on what needs to be done to do this if possible. or is this smart to swap with my rb25 swapi'm not really sure which ratio is best to go with any insight would be great.Thanks Matt
Modified by bobob729 at 1:09 AM 12/19/2009
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I don't know. The Q45 input pinon is beefier I think. I would say you might have to open them up to find out.
r3v_v3ng3
Car: 91 fastback ka-t
it can be done. i did it on mine. do it ONLY if you can get the q45's cheap. requires you to swap the diff, some machining. probably cheaper for you to get other vlsd/lsd unless your going to produce massive power that requires the big 6 spaced out axles
bobob729
r3v_v3ng3 wrote:it can be done. i did it on mine. do it ONLY if you can get the q45's cheap. requires you to swap the diff, some machining. probably cheaper for you to get other vlsd/lsd unless your going to produce massive power that requires the big 6 spaced out axles
i got the whole q45 rear subframe for 100 bucks
r3v_v3ng3
bobob729 wrote:i got the whole q45 rear subframe for 100 bucks
half less than what i bought it. got it for $200 sold the rear 5 lug and brake setup for the q45 for the same price so i got it for free.
now you have to source driver side 300zx TT axle and swap out the diff. put the q45 diff in your 240 casing along with the r&p gear. you also have to swap the shims left to right right to left cause it will push the q45 diff more to the driver side. now you have to take measurements and figure out how much to be machined off. measure and quadruple check it to make sure its right. then you have to find a place to machine it for you. i was lucky enough that this machining place only charged me $20 to do it while others charge $100 or dont even wanna touch it. good luck
r3v_v3ng3
oh yeah its the driver side input shaft that needs to be machined
correction output shaft
Modified by r3v_v3ng3 at 11:13 PM 12/20/2009
bobob729
r3v_v3ng3 wrote:oh yeah its the driver side input shaft that needs to be machined
can't i just put the 240sx ring and pinion in the q45 casing and that would be easier right?
r3v_v3ng3
bobob729 wrote:can't i just put the 240sx ring and pinion in the q45 casing and that would be easier right?
it'll be easier to put it on the 240 casing so you dont have to remove the input shaft and pinion gear
bobob729
this may be true but it'll save me the money of having to machine it down too
r3v_v3ng3
you have to machine it regardless. the q45 r&p gear put the diff in the middle when you install the 240 r&g on the q45 diff it will be more on the driver side so it'll be your output shaft that would need machining. you'll see what im talking about when you do this
bobob729
r3v_v3ng3 wrote:you have to machine it regardless. the q45 r&p gear put the diff in the middle when you install the 240 r&g on the q45 diff it will be more on the driver side so it'll be your output shaft that would need machining. you'll see what im talking about when you do this
o i see so if i put it in the 240 case i need to machine what? and when you said move the washers from left to right and right to left which washers are you talking about and which side will i have to machine
bobob729
heres a pic for reference
r3v_v3ng3
bobob729 wrote:o i see so if i put it in the 240 case i need to machine what? and when you said move the washers from left to right and right to left which washers are you talking about and which side will i have to machine
the q45 rear end is basically r230 internals in a r200 case. so its the same casing as the 240. it looks like the side bearing spacer and washer would switch to the other side of the bearing. the one that needs to be machined is the q45 i believe the driver side output shaft, the 6 bolt that attaches to the axles which is not on the pic. ill see if i have time this holiday and remove the rear end and maybe do a tutoral for someone who wants to try it. its hard to explain, i have to take pics of it. but once you have it out and swap to the other side you will know what im talking about
bobob729
that would be great well i guess i'll figure it out
