placham »
https://forums.nicoclub.com/placham-u38577.html
Thu Jun 19, 2008 3:33 pm
Looks like I'm a little late.
But here is my 2 cents
I'm running a Q45 VLSD in my 240sx. I used the stock 240sx drive shaft flange on Q45 pinion. Same size and spline count. This could be some useful info for people looking to go with Q45 Diff. As some may know until know most people use to drill the Q45 bigger pinion flange with correct 240sx drive shaft bolt pattern. If you use a puller (which makes it a whole lot easier) to remove both pinion flanges, and throw the 240sx flange on Q45 diff. It will save you bunch of time with drilling and tracing bolt holes.
Knowing this, I wouldn't be surprised if the guts are interchangeable. And since the covers fit god knows how many different variation of this diff. But axle flanges are differential carrier specific(part where your ring gear bolts onto), come in different sizes. Q45 being the beefiest of them all.
Hope this helps out someone else interested in this.
Oh by the way to run Q45 diff you need, Q45 driver side axle, and 300zx TT driver side axle, and the Q45 or 300zx TT wheel hubs (5 lug), have bigger bore and spline count for axle shaft then 300zx N/A, J30 and 240sx.
300zx axle on driver side, and Q45 axle on pass side.
