'97-01 Q45 is an R200, and will bolt into your subframe...but you'll need to change the input flange, and find axles that fit ('92-93 J30 axles).
The output shafts have a different spline count as compared to S13/S14/Z32/J30 VLSD 6-bolt output shafts.
This is NOT exactly a bolt-on deal...so don;t bother if you're not serious.
Here's a writeup of a guy who put a Z32 non-turbo diff into his Q45...so if we can put the non-turbo diff into our cars using J30 axles (tried and trued)...then the Q45 *should* bolt in, using J30 axles...assuming you can get a Z32 non-turbo input flange.
http://fgy33.tripod.com/id28.html
- Brian
