240SX rear brake pad replacement
wonS14aero
Car: 1995 Nissan 240SX
How do I move the piston on the rear brake caliper on 240SX?
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The surface of the caliper piston has an X pattern on it; use a large screwdriver to turn the piston clock-wise to retract it and counter-clock-wise to protract it. Keep an eye on the seal while turning the piston so that you don't tear it.
teddy
Car: Saab Turbo and MR2
Yep, just twist it in clockwise. You don't want the piston popping out and you don't want to tear the seal around it. I just used some channel locks to twist it all the way in.
wonS14aero
Thanx for the help fellas
golgo13b
Car: '92 240SX / '91 300ZX
What kind of Pads are you running?
wonS14aero
OEM for now.
golgo13b
Whassup mane? I was poking around as i tend to do... check out this link and tell me what you think. If im reading this right, it means we can get R33 skylines here, but i'm not sure. http://www.nhtsa.dot.gov/cars/....html
golgo13b
nevermind. the very first stuck post on the skyline forum.
