240sx rb25det motormount
douahawj
Car: 240sx
hi i was wondering if anyone knows where i can get a rb25det crossmember or cheap motor mount for a rb25det swap for cheap also i have a rb20det metal head gasket.
Blown240sx
Car: 1996 240sx
25 has TopHat or McKenny mounts. Although I lauph when I see how easy they would be to make.
ISUJinX
Blown240sx wrote:25 has TopHat or McKenny mounts. Although I lauph when I see how easy they would be to make.
Does anyone have personal experience with both? I need a set (and dont have the shop to fab them...) The mckinney's are like 625, the TopHats are slightly cheaper, 400ish IIRC... Whats the major difference? Is one better than the other?
BoostFab
Car: S13cp, S13fb, S14z
exactly, i think the mck ones are just pure rip-off...and they're not even CNC. a couple plates cost less than $20 in materials.
Blown240sx
Car: 1996 240sx
Me and my buddies are thinking of making Mount like McKenny's but wil better fittment out of the box and better bushing setup. Have you looked at the busting? Its two bolts with washers welded on pressed into the poly material... My buddies mounts broke in that spot and the washer cam out of the polly. So we drilled it all the way through and put one large bolt through and it worked great.
ISUJinX
Well if you decide to make your own in the next few weeks, sign me up for a set! Seriously... I'd much rather have something sturdy made by someone who has done the swap than pay $600 for a set thats going to break. Overbuild is way better than broken crap :-D
Any other opinions on them? I'll need a set in the next month, sooner the better.
