My name is Alexander.
From the guy I bought it from, it is in a mid swap. He said that he pulled the engine himself in Japan when he was on military duty. Under 100k miles. It has everything to run except Radiator and Intercooler kit. The driveshaft is from a rb20det on a 240sx, with a Yoke to put it into a skyline transmission that comes with it. Also came with Skyline ecu, harness (injector and upper, etc)
List of things i know I need to do.
Get radiator (will a KA radiator work? or will it not cool the RB enough.) (Budget 2-3 hundred) (cheap the better)
Intercooler. (my budget is around 3-4 hundred tops. (cheaper the better, but without having it be plastic.) just need a kit to get it running.)
Get Skyline harness converted to work with 240sx systems. This si where I need help, is there a Skyline->240sx wiring diagram somewhere?
Anything else I may need?
Any help is appreciated. I am new to these forums also.
Thanks, Alex.
