240sx rb20 no spark.
tgroff12
Car: 93 240sx Silvia conversion and rb20det
Okay so I just got this car and it doesn't run, its rb20 swap 240, the wirering is a mess in it and they also switched out the coil packs for a distributor? I tried the CAS trick but injectors do not turn on or anything when I spin it! Also I checked for power to the PTU and I can't seem to get a reading? I'm stumped any one have a problem like this please help lol!
tgroff12
Could it be an ecu or the ecu coil harness?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
the RB20 has two relays near the ecu. Without those you won't get power for the injectors or the coils. You might want to just order a new harness put the CAS back onto the car.
tgroff12
I will try look to see if they are working, and here is more of the story behind the car not running! He said he was comming on to a highway hit a bump and the car shut off? Do you think it could of screwed one of the relays up?
Yellow4g63
crappy wiring hit a bump something shorted to the frame of the car. Hopefully your ecu still has the LED light on it so you can see the codes it flashes.
tgroff12
Yellow4g63 wrote:crappy wiring hit a bump something shorted to the frame of the car. Hopefully your ecu still has the LED light on it so you can see the codes it flashes.
That's what I was thinking but I don't know where to start looking for the problem, I don't have a light on my ecu or anything. :facepalm:
Yellow4g63
the LED light should be in the ecu near the a circular hole. If your missing the LED then you would need a nissan consult or nissan data scan program to read the ecu. Duno how deep into the rabbit hole your planning on getting with Nissan's tho.
tgroff12
Yellow4g63 wrote:the LED light should be in the ecu near the a circular hole. If your missing the LED then you would need a nissan consult or nissan data scan program to read the ecu. Duno how deep into the rabbit hole your planning on getting with Nissan's tho.
So if I find this light what do the different colors mean?
Yellow4g63
no colors just flashes. if you google rb20det ecu codes you should get numbers. 21= 2 long flashes then a pause then 1 quick flash. 33 = 3 long flashes then 3 quick flashes. There is a screw on the ecu you turn then put the car to on.
tgroff12
Yellow4g63 wrote:no colors just flashes. if you google rb20det ecu codes you should get numbers. 21= 2 long flashes then a pause then 1 quick flash. 33 = 3 long flashes then 3 quick flashes. There is a screw on the ecu you turn then put the car to on.
Okay cool I will check it tomorrow thanks for the info! I'll get back oh here to see if I can find the problem!
tgroff12
So I found the led, it just lights up and stays red the whole time I'm not shure what that means lol!
Yellow4g63
Did you turn the screw on the ecu the other way to put it into diagnostic mode?
tgroff12
Yellow4g63 wrote:Did you turn the screw on the ecu the other way to put it into diagnostic mode?
Yeah I did it both ways and one way it stayed lit up the whole time and the other time was nothing lol.
Yellow4g63
I think your suppose to key off then turn it one way then key on to get the flashes.
tgroff12
Yellow4g63 wrote:I think your suppose to key off then turn it one way then key on to get the flashes.
From what I can tell it's 2 quick red flashes? Any idea? :wtf2:
Yellow4g63
that is prob code 11
tgroff12
Yellow4g63 wrote:that is prob code 11
So its the cas? Would that stop the motor from getting spark?
Yellow4g63
yup, you probably need a new one. double check the plug for the cas. maybe bad connection.
tgroff12
Yellow4g63 wrote:yup, you probably need a new one. double check the plug for the cas. maybe bad connection.
Alright I hope it's that simple lol! Thanks a lot ill try and figure it out hah!
tgroff12
So I got the car started it runs good! But it idles at 3k and when you take it to like 4k it acts like its tacking out? What's the good word for that?
