Nismo_S14Zenki wrote:Sometimes on the highway, it'll seem to loose power or dips in power and will start to gain power again.
Also, does anyone know how to clean dirty yellow headlights like these? If so, it'll be nice to get a few times on it please.
And how about weather strip renewal? My weather strip is losing its color (black of course) ..... its greying in. Does anyone have any advice on how to renew this? I thought of painting it again since it's gotten so grey. Any advice or suggestion would be greatly appreciated.
Welcome
1. Almost sounds like your clutch could be slipping...if you are shifting into gear and get those symptoms. If you are worried about being lean, you could hook up a wideband or get the car dyno'd at a place that will also show a/f ratios.
2. Unfortunately my work blocks images, but if the headlight is hazey then a quick fix is to wax on/off metal polish. Just DON'T touch the paint and realize that this will only last a handful of months before returning. I think there's threads on how to permanently fix it...something about wet sanding and spraying with clear coat or something. Search for it and you may find it if you are looking for a permanent fix.
3. I don't know, Nissan's weather stripping sucks and is stupid expensive. I don't know how good paint on rubber will stand up or look.
