240sx problem
D2Falken
Car: 240sx
hay i have a problem with my 240sx. when i start the car and its cold there is blue smoke out of the exhaust and when it worms up there is less blue smoke but there is still blue smoke. i thinks its the ring on the pistons but i am not to shore. can anyone please help me find the problem.thanks
Amtk240
Car: 1997 Nissan 240sx SE Red S14, and 1995 Nissan Navan 240sx Ruby Pearl S14.
Information I got from a google search:
Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. As with the white smoke, just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe. Blue smoke is more likely in older or higher mileage vehicles than newer cars with fewer miles.
How did the engine oil get inside the cylinder in the first place? The car has many seals, gaskets, and O-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plug, it will cause a misfire (engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder.
AZ89two4Tsx
Blue smoke = oil
Unless you add blue coloring to white smoke.
D2Falken
Car: 240sx
thanks for you answer and i did search on google and it sad if its blue smoke all the time then there is oil getting in the piston but mine is only when you rev and its cold. when its worm there is a lot less blue smoke.
ScrapMetal
Car: 1999 Chevrolet S10
1991 Ford Bronco 5.0
When the engine warms up, metal expands.
AZ89two4Tsx
D2Falken
Car: 240sx
how long do you think i can last with out changing the piston rings and how much will it cost to change them ?
thanks
ScrapMetal
Nah, I just made that up! Metal's metal man! It's motherf***ing rock solid!
A little blue smoke never hurt anyone, just check your oil level frequently. And like Amtk240 posted, use a thicker weight.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Valve stem seals. There is a write up on how to do it here somewhere.
AZ89two4Tsx
D2Falken wrote:how long do you think i can last with out changing the piston rings and how much will it cost to change them ?
thanks
You will want to rebuild the engine once you get it out.
The cost of that all depends on if you do it yourself, or pay someone. Labor is a biaaatch!!!
D2Falken
Car: 240sx
how much will it cost to get some one to do it for me and why to i want to rebuild the engine once i get the rings out
ScrapMetal
Rebuild? porque?
Don't rebuild shizz, replace your head gasket, rings, rod and main bearings and that's it. All that is gonna cost you soooooo much $$$$, you might as well buy another car. I like the Mazda Protege5, go with that!
AZ89two4Tsx
If his rings are fried, doing that ^ will do nothing.
I'd say 2K would be a bargain basement deal. But you're probably looking at 3K plus.
D2Falken
Car: 240sx
i will probably put a new ka24de or sr20
ScrapMetal
His rings are teh problem! I'm just telling him to replace his bearings because he's going to have the engine apart anyway and those things wear over time as well, and his head gasket is a given.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
You cant say what it is. He has tried a compression check yet. If it fails, yes ring, if pass its as simple as valve stems and a gasket set.
D2Falken
Car: 240sx
thanks i will do a compression test tomorrow
