240sx paint question.
megaderk
Car: '90 240sx coupe
so i got some new door locks an handles for my 240 but they are a different color from my car. so i need to get the right paint code to buy the right paint to match my car. i looked online and found some info buy just wanted to double check n get input from others to be sure. i found this chart a few days ago n thats a pic of my car. its a 1990 with the factory paint.
im pretty sure my paint code is the "Cherry Red Pearl". Code: AH3 http://i216.photobucket.com/al...X.jpg
Modified by megaderk at 11:10 AM 7/11/2009
S13Joe
Car: 92 Coupe
Download the FSM, its in there. But wtf is the white line above your tail lights?
megaderk
DirtyGhettoKids wrote:Download the FSM, its in there. But wtf is the white line above your tail lights?
factory pin striping.already removed it
MR.chris
Car: 1995 Nissan 240sx se SR20DET Money Pit
Look under the hood on the firewall and you will see a small aluminum badge with the paint code on it. Be sure to sand the parts with 1000 grit sand paper and use a good primer before you spray base and clear.
megaderk
