DGA »
https://forums.nicoclub.com/dga-u13015.html
Tue Mar 23, 2004 1:24 pm
I will just tell you my experiance with my former 2001 GTI. It was a 1.8 Turbo. I always wanted one and when VW showed a 1.8T in a GTI, I sold my Nissan Frontier and got my GTI. It was brand new, and had all the bells and whistles short of leather. About a year into owning it, I got a GIAC chip for it and the thing screamed. 200hp, and 240 ft-lbs of torque. Very fun. Drove it this way for about a year and had fun. Nice car and chicks dig it, but it was not all fun and games.
From the get go, my transmission would not want to shift into 1st sometimes. You would have to roll the car in second, but no big deal, the car has a lot of torque. Took it to the dealer, and of course they could not duplicate the problem. After that my injectors started leaking, and I had that replaced by the dealership. They started leaking again after my warranty ran out, so I had to do it myself. Typical car stuff, no big deal.After this my engine started misfiring at high boost. Some fouled plugs were the culprint so no big deal. After this my rear brakes wore themselves down to nothing, due to VW putting on softer rear pads to correct their engineering mistake, of rear brake bias. The parts ran me $150.00 for stock crap. This started pissing me off. A few weeks later at about 50,000 miles I was changing my oil and noticed that oil was leaking from the head. Very nice. At the same time my front hubs started going bad. This is when I traded in my GTI for a '96 240sx.
I have done my homework on that car so let me give you a few pointers on what you should watch out for:
Coils - Very expensive, and there was a recall. In 2001 they were made by Hitachi, in 2002 they were switche over to another manufacturer and they started failing left and right. Huge recal was ordered and the coil manufacturer was backed up for 6+ months. Hitachis bolted to the valve cover where the other ones did not. I was lucky and had Hitachis.
MAF - Tend to be very problematic. Tend to fail with cold air intakes, or just on regular basis. No recall. Expensive. Germans being engineering maniacs also installed a version of a MAP sensor, so that you can run without the MAF for a little while without huge diverse effects.
Turbo - If you decide to go with 2001 GTI they have K03's. Small and 70's technology, but cheap. It runs out of steam at 5500. Red line is at 6500. 2002 and up came with K03 Sport. Slightly better. Tend to fail due to them being over stressed with tuner chips.
Window regulators - There were recalls, due to windows falling into doors. Pain in the *** in the rainy NW.
#3 cylinder tends to be the one that will blow out, I mean blow a hole in the block, but this is rare due to the 1.8T being a very stout engine.
Transmissions - Weak, and tend to break.
Clutch - Weak and tends to go out fast, even under stock power.
Boost - You have to get chips because the car has a electronic throttle, and no boost controler will work correctly with the Bosch computer. Hard to fool the ECU period, unless you have a custom burned chip.
What I am trying to say with all this is that my experiance with my GTI was very fun till it started to break down. Very expensive, and harder to find parts. I did all of my own work on it, and let me tell you that bastard is very complicated to work on. I did not drive my car hard, at all, but I did drive it a lot. My GTI's failures were the same as most others, but I had less of them. Check out VWvortex.com. They have all the info that you will neeed. Some people are asses, and do not know jack, but there are a few that really know their stuff. Just remember, 1.8T engine is going away in the new GTI to be replace by a 2.0L turbo. Good luck.
